Hey guys
Ive had a problem with my clio for a month now.
I thought it had a cold running issues, with severe kangerooing. (More than normal)
Also stalling, when cold, and not starting on the first turn of the key.
I have had the following things done.
Cleaned Throttle body
cleaned crankshaft sensor
new plugs and HT leads
New lambda sensor
I still have the problem but I have discovered today that its not a cold running issue but its;
Misfiring whilst driving uphill. When I drive home from work, its in a steep valley and it wants to stall whilst driving on hills, even when really accellerating.
Which causes a huge spate of kangerooing, and no accelleration.
It is so dangerous as when you pull out infront of someone, even if they are quite far away they are literally right up behind you.
I just assumed that because it was still cold, it was a cold running issues.
However It did it when hot today, whilst driving uphill.
So what could an uphill misfire be caused by?
Sorry if it doesnt make too much sense as im on the phone.
New lambda sensor
