172 Gearbox Differences
  Clio 172 Sport
Just need some advice im after a gearbox for the 172 mine is the ph2, a member is selling one on here from a ph1 will that be the same as mine?
  182/RS2/ Turbo/Mk1
There are essentially 3 types of box
Higher geared diff:
Ph1
Lower geared diff:
Early Ph2 or Ph2 Cup with speedo drive
Ph2 non speedo drive (172 or 182)
If you have a non speedo drive, you can fit any of the above.
If you have a speedo drive (ph1, early ph2, ph2 cup) then you have to fit either a ph1 or early ph2
If you fit a speedo drive to a non speedo drive car, you need to add the actual speedo sender to the box to blank it off (doesnt need to be a working one but they are only 13 quid new) or make some form of blank.
  RS RIP
^^ This thread suddenly got me worrying! I'm in the middle of changing the (ruined)engine on my 172Cup to a Ph1 lump. Will this Ph1 engine run/fit on my 172Cup gearbox ? :eek:
  RS RIP
phew ! Good to hear because i'm skint.. last $$ spent on conversion and new Schricks on ze way!
​cheers
