'04 172 rear brakes
  clio 172 2004
i am wanting to change the discs and pads on the rear of my '04 172
i have the discs and pads on order but will i need any kind of pins or clips ? if so what will i need please ?
  Listerine & Poledo
Depending on their condition, you should be able to re-use your old springs, shims etc.
non-Renault pads wont come with them...not sure if genuine ones do or not actually.
Mr R.
  A special one.
You don't need anything bud.
There's an R type clip and a steel slide that can all be used again.
Mr R.
  A special one.
Hmmmmm. Remember to remove the washer from behind the old disc's and remember which way round it goes.
I'd replace the hub nuts as they are nylocks.
Also you must torque them back up to 175 nm. Failing to do this may fcuk up the bearings.
