Williams 2 & 200
Right I have a couple of issues and I have tried searching! Basically the inside edge of both tyres are bold, i've just had the tracking done and the pass side was well out but the drivers side was seized, the pass side has now been sorted but could the passenger side cause problems with wear on the drivers side and do you think there is anything else i should check?
Regarding the brakes I changed both front pads and discs but the outer pad on the pass side is not gripping the entire disc. I've re-stripped the brakes and re-assembled and everything seems fine so i'm not sure what could be causing this apart from a non flat pad surface?
