100% complete 172RWD! - updated
stevo172-RWD
  clio 172 rwd
Re: 80% complete 172RWD! - updated
Stevo - I ordered my Adaptronic E420C last week for my Clio - should have it in a couple of weeks time. Going to be running it in conjunction with my new Jenvey throttle bodies. Would be good to bounce ideas off each other should we run into problems.
well i havent ordered one yet pal but i will post every step when i get it :)
  Vauxhalls
they dont really have a cam sensor
only a depahser solenoid you may be confusing it with and it runs without this
Oh ok then, thanks for that. i thought the Dephaser ran off oil pressure similar to the Honda K20/K22 engines.
You learn somthing new everyday lol
Im Guessin your a Renault Tech Ditz?? or somewhat linked to them?
  LY 182
its activated by oil pressure but the solenoid just opens and closes a valve to allow it to pressurise the dephaser
actually work in a jag specialist garage, renaults are just my thing if you like.
stevo172-RWD
  clio 172 rwd
yh my thing too;)
stevo172-RWD
  clio 172 rwd
heres a little update.
iv so far perfected all foeward gears 1st,2nd,3rd,4th,5th:)
.......but so far no reverse lol. :S
little trish should sort it.
stevo172-RWD
  clio 172 rwd
another lil pic.
so busy at work and finishing car only have time to post at night lol
then i forget cable;)
stevo172-RWD
  clio 172 rwd
brakes so far from a citroen fwd handbrake:)
stevo172-RWD
  clio 172 rwd
hope to sort a clutch out this weekend too
then she needs brakes conected for a lil test drive lol
  Clio 172 Sport Ph2
Wow Great Read
She running now?
yh well sorta:)
think i shoult change fuel pump as its over fueling even on prime up?!?:S
Mate....a bigger fuel pump wont cause overfuelling - after all it only provides enough fuel as the regulator allows!! ;)
Good to hear its nearly there though mate.....expect to see some sideways action soon! LOL :evil:
stevo172-RWD
  clio 172 rwd
yh well sorta:)
UH WHAT regulater would that be then mate?lol
the one after the rail?
im not using 172 pump/reg setup.
stevo172-RWD
  clio 172 rwd
no regulator? that would explian it then!
regulator is on retern side of rail.
same as k-tec use on there turbo setup.:)
needs to run to regulate.
prob going to fit a vw golf inline pump.i think it has to be vari voltage pump?!?
going to have clutch this weekend!
then just need brakes!
  '91 Clio RT =D
almost finished then mate?
been looking at this since about 60% :)
looks amazing, what do you do for insurance?
A
ashy_gtt
Still wont cause it to overfuel at idle unless your injectors are stuck open? Is your MAP sensor conected up ok? maybe the ECU isnt seeing the vac and running on the 100kp section of the map?
stevo172-RWD
  clio 172 rwd
it was not even trying to start b4 as fuel made plugs wet before they had a chance.
anyhow it works now so what the hey!
then just brakes!(needed)lol
as for insurance i have none atm as its off the road!.
stevo172-RWD
  clio 172 rwd
i brang it to the last one also!were you there justin?
I was mate. Myself and burp were the two chaps who came over and had a look at it on the trailer.
ah you too lol.:)
yh i know lol
so when is next airfield meet then?;)
if its not running by then (on the road)im sure i can trailer it there again and mybe run it on airfield ;)
stevo172-RWD
  clio 172 rwd
few pics off the gear linkage and my made up clutch;)
it works too!
stevo172-RWD
  clio 172 rwd
some new ones.
have new vids too which sould be up later.:approve:
CgT
  Escos Replica (W.I.P)
o wow came across this on youtube a few weeks back, gotto admit intrestered in seeing how this develops, best of luck! :)
stevo172-RWD
  clio 172 rwd
yh there is varous vids on youtube of my car by different users lol.
will get all the links on one page soon.
this car is going to be mental when done ;) .
my next car will be a v6 :lolup:
stevo172-RWD
  clio 172 rwd
well done mate, you cracked the running fault?
yh turned out to be a stupid loose wire on ecu connection pluss the plugs were clogged right up!
overfueling.
going to go adaptronic standalone ecu later.
  LY 182
ah well, well done sorting it anyway.
looks an animal - it gonna be at fcs? wouldnt mind a nose around
stevo172-RWD
  clio 172 rwd
found out half my running problems was down to the fuel pump!
iv now ordered a 12mm inlet 8mm outlet facet high pressure(fuel injection pump lol)not a redtop facet for carberretors!
also had to get my swirl pot fabricated with a 12mm outlet!
will still run crap because of the map tho.
  '91 Clio RT =D
yer but when its on the road how will you insure a rwd 172 cz urs is the only one?
