BoatNonce
Hi hi.
Missus' 1.4 mk2 has climate control. From what I can tell, everything works - the aircon certainly works brilliantly, the heater blows hot, the flaps move... but for some bizarre reason, if you adjust the temperature (even going to max/min), nothing happens. It keeps on blowing whatever it was blowing.
However, if you key the ignition off for a moment (even on the move) when it comes back on the climate immediately adjusts itself perfectly. However, of course, it doesn't do anything as the car warms up/cools down so there's no actual climate control.
Anyone had this? Seems bizarre. I know the climate sensor in the roof lining isn't buzzing which probably isn't a great sign, but surely even if the climate sensor was dead, if you whacked it up to max it would override the temperature control and just go straight to full hot, and same for cold?
Cheers for any help.
