Harnesses - talk to me
  Z4x2 & buying a 182
So I have just fitted some Sparco Sprints into the 182 and now am looking at harnesses.
I am on a budget and am only on 2 track days so far - 3 and 4 are in September.
3,4,5,6 point harnesses, 3 inches or not etc...what should I be thinking about?
Thanks
robzracing
If you’re only doing track days a 4 point will be fine. (5 point is better but more awkward) Without a cage you just need to find a way of mounting the shoulder straps behind you.
This angle is critical.
3 inch straps will be the most comfortable unless you use a HANS device in which case 2 inch.
  Z4x2 & buying a 182
Thanks that is helpful - in terms of securing I looked at the harness bars but they look pretty expensive considering you could put that money towards a cage?!
robzracing
I have a bar welded between the 2 shock turrets. Independent of the cage. Maybe you can find a local fabricator to do this? Shouldn’t be too costly.
massiveCoRbyn
  Several
Exactly as above. If it's only a handful of days a year, just fit four points. 3" straps are more comfortable.
Simon1975
  Clio 182 Cup/Meg R26
I found trs to be good value and quality. They do a 3 point with seatbelt buckle if it's mainly road use
Robproof
  Clio 182
I’m not experienced at all things Track day cars (just picked my Clio up this year) but, Recently fitted a “unuversal harness” bar to sort the angle of the harness’s, it’s not cheap, but it’s good quality and from a reputable source (Tegiwa).
just while I decide if I fit a cage / half cage
dann2707
Seen a few of them snap or bend in the past so I definitely wouldn't feel safe in that :eek:
Also learn how to roll your excess harness properly :p
Simon1975
Personally a decent half cage for around £550 is a safer option. Especially if being used on track
  Z4x2 & buying a 182
Yeah I just had a great chat with Mark Fisher motorsport who use safety devices and think I am just going to go for a race spec half cage which can be converted to a full cage at a later point - safety first!
Simon1975
Safety devices and fulcrum both do the rear cages ready to add front at a later date. Both really good cages
Cub.
There is a very good link to a schroth harness guide in here;
Ph1 Tom
6 point all the way. Although there is the option of the anti submarining (ASM) type by Schroth.
If you speak to Steve at Sabelt UK he can sell you a set close to end of FIA approval or out of date at a cut price. Perfect for trackdays.
In terms of installation the guide the @Cub. Posted is a good read. For the crotch straps, fit a spreader plate under the floor and an eyebolt to clip on to. Iirc if the seats are mounted low enough I think the bolt holes in the boot area just behind the rear seats give a decent angle.
  Z4x2 & buying a 182
Thanks guys, I had a lobg chat with Mark Fisher recently and think I'm just gonna get a proper half cage sorted in october/November and will probably get them sort harnesses a well I imagine.
Safety first!
I
