Thanks - makes sense. Is there a simpler way to get the heating controls working again without replacing the loom? Not bothered about AC.
Electrics not my forte tbh.
Checked cogs and they are fine. As I understand it climate won't work without the sensor?The heat issue may be down to the cogs. Search on here it's a common issue
Thanks. I really am a dummy when it comes to electrics. To connect the CC sensor do I need to replace the entire loom, or just a bit of it? Do I simply plug the required section into the green plug pictured, or do I take the dash apart?Thats the plug that connects the loom, the white plug is the tweeter.
@Mbeau any luck finding wires?
