Temp needle up and down???
The Chubby Pirate
  Golf R
Replaced the coolant temp sensor (right hand side on block) and the needle is still rising and falling?
There doesnt appear to be any actual issue but it still makes me worry?
its a Phase 1 172 btw.
cheers
Rob
That's what I was about to stat, thermostat starts to go, (or if it's always done it, someone's fitted the wrong one), so it's getting way above regular temp before it opens, the water's circulating, cooling it, it's closing, and repeat.
The Chubby Pirate
  Golf R
Hmm, its defo an original going by the shape of the pipes etc.
Anyway to strip it down or is it better to replace?
Rob
It's cheap as chips to replace mate, you can't see the thermostat to see if it's original or not though.
It'll need a decent coolant fill up but it's not a hard job.
The Chubby Pirate
  Golf R
Ahhhh i see! I was mis led! :eek:
Is this inside the metal housing to the right of the engine? (Near the coolant sensor is?)
cheers Rob!
Rob
That's the one, three bolts to get it out iirc.
The bleed screw is the bolt on it. Personally I'd just open bleed screw and bleed into a funnel going somewhere, unbolt thermostat housing, remove thermostat, replace thermostat, re fit thermostat housing, re fit bleed screw, fill up, undo bleed screw a bit to check you've not randomly trapped some air, and refit.
Then just run it up to temp with the cap off, wait for the stat to open, then fill it up if it needs some.
Rob
Think there is mate yes, and if there's not one in the guides section, a few have written out the process better than I just did quite a few times before.
  Clio 220 Trophy
That will be your thermostat had the same issue on mine, replaced the cts and thermostat now runs perfect no issues with the needle gauge got my both parts from renault as i always get my parts from there part no for the thermostat should be 8200772985
The Chubby Pirate
  Golf R
I gather its in here;
(note the shiny new temp cooler:mad:)
  172 PH1
I honestly wouldn't have thought a fault thermostat would cause that symptom.
At what points does it mainly rise/fall on the gauge?
  Clio 220 Trophy
Yes, not the three side bolts you see in the image plain but there are three more, you can see one of the three bolts head on. One of them looks a bit bronzy on the front there! Thats one of the three to access the thermostat. The other one is just under it you will have to move some of the grooved cable cover next to the big pipe to see the other one on top. But fairly easy spottable.
If that makes sense lol.
The Chubby Pirate
  Golf R
Randomly mate, sometimes it doesnt happen for a few days then it does. Like i say, it has no effect on the car performance wise.
It will affect MPG though as i would imagine, i give it pretty much 10/10ths everywhere so if something was going to break it would have by now?
The Chubby Pirate
  Golf R
Cheers Jonny, yeah i know the three bolts you mean! I gather the bolt furthest to the top on the side is the bleed one as it doesnt seem to be holding anything in if my amatuer mechanics serves me right lol
  Clio 220 Trophy
That's the one :)
hope it goes well for you , be careful that you don't drop any of the bolts down the engine bay :/
The Chubby Pirate
  Golf R
I gather this is better to do when the car is cold? Also, how are people catching the coolant that im likley to lose as a result of taking this apart?
The dealer that fixed my temp sensor issue said that the fault was a wiring problem at the sensor. Not the sensor itself.
  clio 16v
Is the needle flicking up and down quickly?
If it is, srsly don't waste your time on the thermostat.
This.
Don't want to alarm you but if its going up and down really quickly check the head gasket. I had this on a 205 gti year's ago and head gasket was leaking gas into the coolant intermittently and causing temp spikes.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Deffo a cooling circuit fault that. There's no way a stat would make it jump as described if it was faulty.
My guess is massive airlock, faulty CTS (unlikely) or head gasket due to incorrect maintenance.
Mick
Rob
He doesn't say rising and falling really quickly does he?
He just says rising and falling? So I though maybe, car gets warm, car gets warmer than usual, finally stat opens, temp drops down, stat closes, repeat?
The Chubby Pirate
  Golf R
I dont know where people are getting the needle going up and down rapidly from, it does it once every few weeks, it'll rise slowly then come down to half way again.
It gets driven at 10/10'ths absolutley everywhere, there is nothing wrong with the head gasket. :S
For anyone interested, its all good now, even with my panther like reactions some of the coolant managed to escape so i went to Reno and bought some Type D and topped it up, all is well and good in the world with the green machine;
The Chubby Pirate
  Golf R
Just went a wee drive, seems the issue still exists LOL.
What else can/should i check? The thermostat and coolant sensor have both been changed, bearing in mind there isnt an actual problem to report of??? Car drives fine/no smoke etc??
  DON'T SEND ME PM'S!!
is the cambelt due? might be in need of a water pump, seen an odd issue like this and found a couple of impellars broken off the pump. Was a bit weird
need to pay attention to if the rad fan stays on more often that you'd expect, if you're using the heating in the car more, general things like that. Doesn't sound very serious though, just varying temperature.
  172 PH1
Might be bett if you can explain exactly when it happens? More often when you are driving on motorway etc? Or in traffic?
There is only a few realistic things it can be.
