From inside the car.
If you're sat in the front seats, then just above your head are two lights. One of them is the light that comes on when you open the doors, the other one is a little map reading light that you point in various directions. These are the interior lights I was referring to.
If you remove the plastic panel they're sat on at the end closest to the windscreen, you should gain access to the rain sensor mechanism.
