People who know F4R Engines
  206,172 Cup,focus,X5
My 172 cup has got 68k on the clock and im gonna be ripping the engine out this weekend to see what is what as it has been very neglected and to do the cam belt , dephaser etc, so just wondered what these engines are like at this sort of millege , what wears out first, do shells last a while, what about rings and bores
How long do the cams last before needing to be replaced
or anything else I should know :S
cheers Ben
  182/RS2/ Turbo/Mk1
Ive seen them detroy the pistons and spin the shells at less miles than yours has, and have also seen them do 150K miles with no problems at all.
To give you a slightly better hint, we just need the following simple bits of information from you:
Details of how often the oil was changed, and what oil was used.
Details of how long each journey it performed during its entire life was, and a plot of the revs and temp and AFR during each of those journeys.
And then its just a matter of guesswork on things like if you got lucky with the piston ring lands or not.
:p
Seriously though, common failures are:
Cam timing done wrong effects performance
Bad mapping washing bores and ruining rings
Bad mapping causing leaness that leads to ringland failure (they are poorly made pistons)
But in the main, if well maintained, left on a sensible map, and not thrashed from cold, you should get no problems at all, they are overally very reliable.
mikeh
  182 Trophy
164k here, no significant oil usage and still pulling strong.
The car had FRSH when I bought it at 134k and has had the oil changed every 5-10k since.
Watch it fail at Brands on Friday now.
John Gordon
  Clio 2.0 RS 172 Ph1
I thought I was one of the higher on 142k.
mikeh
  182 Trophy
There was Nick's old Trophy on here that finally threw a rod at 180 something.
I don't think I've seen one higher than mine, other than that. There's a highest mileage thread somewhere.
I have no service history at all !!!
The oil filter has rust on !! So god knows when it was last serviced.
I suppose its a case of ripping it apart and see what is what tbh
when i drove her the 301miles back from bradford it didnt use any oil at all so thats a bonus i guess
loggyboy
Like with most things, if aint broke................ rag the f**k out of it till it is. Then deal with it.
IMO When cars are as old as most 172/182s are now, and parts and cheap and easy to get hold of, spending a fortune on preventive maintainance is a false economy. Not including the obvious things like Cam/aux belts of course as its silly to ignore service intervals on them.
mikeh
  182 Trophy
Indeed.
You can pick up another engine for £200-400 generally. Do the belts, change the oil and rag the crap out of it.
  182/RS2/ Turbo/Mk1
Guess I beat you there, mine's on 282k now :)
Old ph1 from a former Cliosport member though. Dunno if he has the same name, but he is known as Epsilon.
Is that KMs or Miles?
If its KMs, then that equates to 176K miles, which a couple of people on here have also had, I dont think anyone has hit 200K miles yet though on here.
  Clio 172
My bad, metrics and stuff, that's 282k Km's yes :)
I will definitely not hit the 300k Km's, as I am only driving like 100 km's in the weekend. :)
John Gordon
  Clio 2.0 RS 172 Ph1
Some pretty High mile ph1's here in NL then.
I wonder if I can hit the 200k Mile mark. I drive it fairly sensible on the roads because my drive to work has a 100KPH Trajectcontrole. It does however do a few track stints, although I do try to be mechanically sympathetic. No bouncing off rev limiters etc.
fingers crossed!
  ph2 172
Probably worth sticking an engine flush through it before you drop the oil out if its not been serviced in a while.
Ive got one engine on 66k that was very clean inside when i opened it up had the oil changed every 6-8k, the other one at 85k was black inside due to burning oil and poor maintenance.
John Gordon
  Clio 2.0 RS 172 Ph1
I seem to remember reading that on older engines it can do more damage than good when using a flush. Unsettling old carbon deposits that are effectivly filling gaps etc?
I could be wrong, just curious.
  182/RS2/ Turbo/Mk1
Yeah after a flush you can find that seals that are old but so gummed up with deposits they dont leak then start doing.
I do have a engine flush so I will use it and see what happens but I do want a fresh engine when im finished and want have any leaks
If I can build rs turbo engines with out them leaking then this one can defo be done lol
mikeh
  182 Trophy
I'd avoid an engine flush unless you were doing it with each oil change from new.
As people have already stated, they can make seemingly good seals start to leak and there is a chance of them shifting but not breaking down deposits that then block smaller oil ways.
  ph2 172
He's rebuilding it anyway isn't he, so new seals would surely be used? Might make life a little easier cleaning bits up flushing first.
Coops Mk1
  Lots of Scrap...
just about to clock 121k here, full history and oil changes every 6k since I've owned it. about to do the aux belt this weekend and then it'll be good till cambelts due late next year :)
Well i bought the flush before i was going to rebuild it anyway. So i may as well use it for the sake of 2.99 who cares.
And yes i will be using new seals and gaskets.
Do most people use dealer for gaskets and seals ? Or is there any other specialists and cheap prices around ?
