Danith
MX5 ND2/220 Trophy
OK - I await all the 'don't be a fanny' comments and 'its 50/50' or 'my mate's has been on 3246236 bhp with no issues' :smile: - I'm not a gambling man, I don't do 50/50, but yes, I am a fanny.
So my Megane R26 is currently on ktec turbo back with sports cat, 630cc injectors, ramair open cone, pro perfekt recirc and 60mm intercooler. It made 276bhp 301 (capped) lb/ft at EFi.
After now reading up on numerous megs now failing on blown engines recently (mainly due to cyl 1 fuel starvation causing ringland failure, rather than bent rods due to torque), I've decided I don't want to be driving around in a ticking time bomb as I really don't need the expense or hassle for a few extra bhp/lbft, so I'm going back for a detune, it's not like I need all that power - think it wasn't far off being perfectly balanced after the sports cat but hey ho - it definitely needs mapping to suit the bolt ons to be safe and have the emissions light for SMF mapped out.
So would like to know regarding leaving the 630s in - although RS tuning did recently publicise that oem injectors are at almost 100% duty even on a standard map (plus oem injectors are about as reliable as Conservative's NHS promises), so 630s may be better to reduce the risk of fuel starvation - however, do they put more stress on the fuel system? Really it all sounds down to a poor fuel rail with no return - but then how does mapping increase the instances of engine failure if it's down to a crap rail!?
