Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
hi everyone...... i've got a problem with my climate control on my clio 172... cant get any cold air in the car.... every thing appears to be working (you can hear the ac compressor engaging)...... but no cold air...... HELP!!!!
yea fan works on all speeds.... just cant get it to cool the car down.... if you set the temp at 16c the cabin dosn't cool down its always hot air thats blown......
I have a bit of similar a problem with my air con in my 2002 172...
It only blows either hot or cold, no in between. If it is set on any temperature below the max heat it will be cold but if it is on the max heat it will be as hot as it should be.
Would that be a regas or is the thermostat just buggered?
