bmh.01 those be ok on a 2002 clio dci ? Could you go any higher than 4300 or is there a reason for that specific bulb you recommend?
are they different to the normal kits as they are alot cheaper than other kits i`ve seen
the reason he said that temperature is the colour is at its whitest which means vision will be improved best, the higher the temp the fancier the colour but the vision isnt as good
You've got projectors so you could fit HIDs if you wanted to.
http://cgi.ebay.co.uk/XENON-H1-H3-H...oryZ9895QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'd get 4300k myself. Fitted a few of those kits and the quality isn't bad at all really.
None of them are "legal" due to a lack of washers and auto levelling, but those will be fine.You've got projectors so you could fit HIDs if you wanted to.
Is that kit one of the legal ones?
Yepso that link to that kit will do good in my car matey?
Plug and play no bother, i'm not too far away if you wanted them fitting let me know.how easy do you find them to fit BMH, i was going to buy a kit off one of the lads on here but if these do a simiila job and i can get some one to fit it
can you fit them on the mk2ph1 clio's with dual optics?
Saw 8000k at the weekend and was very noticeable.always go for 6000k on HIDs
thats the same colour as OEM cars with xneons,
never ever get 8000k
Certainly was.^ almost purple!
