wiring boot help
  clio mk2 ph1
hi guys my sisters boyfriend bought a 5 door ph2 1.2 but its had a rear shunt and someone has very badly put it back together , the boot has been put on, but where the loom comes under the headlining all the wires and washer pipe have been cut and left underneath the headlining. so this means the top brake light doesn't work it doesn't lock and the rear wiper doesn't work , my question, is there a loom coming out of the boot lid to connectors where the wires have been cut or should the wires be long enough to go down the the individual things and plug in ?
cheers tom
  A.N. Other
IME in general (not with Clio boot looms specifically), you get two separate looms with connectors in the headlining/bootlid to connect them together, it's not one long loom.
