Titanium 182 - small scratch
  Titanium 182
Hi All, got an 05 182 that came with a small scratch anout 8mm long on the bonnet, doesnt seem too deep but dont really want to get it resprayed under warrantee as I feel it will start to look different from the rest of the car.
Any idea what I can use to fill it up, I noticed on packs of coloured T cut or something similar they had some chip sticks which looked like hard wax that you go use from side to side until the scratch is filled, anyone had any edalings with these things, anyone recommend something better from Renault etc?
Cheers, Neil
  Mondeo STTDCI
If theyll respray get it done. If its worth respraying then nothing you can buy will fix it.
seb
  Clio trophy
def take it back and get reanult to sort it out matey...
  Lotus Elise Cup250FE
Cruise control is always out of sync.
My Speedo, Cruise Control and GPS all say different values.
® Andy
  Illiad V6 255
Yep ... cruise is done off the ABS sensor which is more accurate than the speedo which is set a little bit high to protect your license ;) As for GPS ... Ive always been slightly suspicious of instantaneous readings especially at lower speeds ... is spot on for averages over longer distances tho.
