Removing bumper inserts
  850 T5. mmmm Turbo!
anyone know how to remove the front and rear inserts on a mk2 ph2??
ill do a DIY guide to colour coding them if anyone thinks it would be useful.
  Chocolate Bar™
front one has to be 'peeled off' from one end. obviously you need to remove the two ends before the centre section can be removed as these are in the way.
as with 90% of clios they're attached with the plastic triangular wedges that lock into the bumper. to get out its difficult to describe as you have to force a blunt knife inbetween the top of the insert, and the recess into the bumper. you can then, in effect, push the wedge down and force it out.
difficult to describe, but once you've done one it'll fly off. the only difficult part is pulling it forward so that you can see where the little lugs are (they run all the way across the top and bottom)
Mark
  Chocolate Bar™
back bumper has two screws at the top, and then the same little lugs across the bottom.
  clio mk2 1.2 16v
I went to a bodyshop n he sed ya cnt get the front or back bumper strips off! must av bin lyin. Yeah m8 that wud be well usefull, bin lukin4 a colour coding guide for a while
  Nike Lunar Elite's
If you'vbe got a mk2 ph1 then they won't come away from the bumper, but otherwise he's lying lol
  850 T5. mmmm Turbo!
they come off alright.
have a look at www.harrymanback.com/diy.doc
its a bit messy but i add a few pics to the original one, plus some of my own words of advice.
thats for a mk2 ph2
