Rear side window seal leaking
Polynesian
  Alpina B3, 172, 325i
Just that- the seal around my rear side window has been sun damaged and is now leaking… can you get replacements or do I reseal the glass? I thought it used sealant as well as a separate rubber piece. Thanks
MRBILLYUK
  FF Jeden Osiem Dwa
I'm pretty sure it's like you said, they use a sealant to put the window in.
You're probably better off taking it to a windscreen place and they'll take it out and reseal it.
Polynesian
Thanks, one more thing to do! You can see that the seal has failed- the old black rubber is frilly now where it’s been distorted by the sun.
