lost my bloomin keys
muz
  big fat japanese bus
at this time of year too :(
what can I do ? its a 03 172 btw
Can I just get renault ot make one for me, what about the alarm? Will it need recoded
this all sounds expensive :(
  Shhh
You not got a spare.?
If you have the spare, then you can use that for awhile. Think a new key is about £110 ish. If you have lost them both, then i think a new lock set maybe required, and to reprogramme the immobiliser.
  C63 AMG, F430 & 172
replacment plip is 100 from renault. program is 40, key cut is 30 iirc. but u can get plips for a 10er off ebay.
The key is a 2 part thing the metal bit which assuming you don't want to go changing barrels etc (£160 or so) is £40 a metal key I think but it takes a few daays to order from France.
The remote bit needs to be programmed from a dealer (approx £100 all in a key) with a blank fob you'll need to take the car with you so they can deactivate the lost ksy so it won't open the car altough you can have upto 4 keys on the car.
muz
looks like I am well stuffed I am sure it is in the house searched the drive and all the bins
THe other key was losta ges ago and I never got round to getting a replacement
My problem is now how the hell do I get it to my dealer?
Also the car is unlocked!!!
muz
no garage mate plus the wheels are turned so I cant push it anywhere straight.
We stuck the celica behind it to stop someone stealing it but feck waht can I do ?
Bloomin keys :((
oh fcuk./ shouldnt the clios self lock after a certain time??? it happens to mine when i closed the door and the keys out of ignition
  Shhh
Open boot, climb in and press the central locking button.
Climb out of boot and close boot.
Unsure if the boot will be locked or not, tho both door shall be locked. You could try to frig the boot sensor so that it thinks its shut so it locks it, tho then you have the hassle of getting it open again.
Id go with leaving the boot option open, most people wont check the boot. Leave the parcel shelf out to show that nothing is in the boot, and empty the car. Nothing you can do till tomorrow....or the days after etc.
Could strip the door interior out, get to a scrap yard and buy a lock for the door with key if possible, fit lock and lock car via pressing the central locking button option.
Good luck.........
  Shhh
Self lock if the car is unlocked, and door not opened, then allowed a set time then relocks itself.
For now the best idea is to ring the AA and get them to take your car to Renault.
You have a few options
1) Brand new set of locks £190 for the locks then £100 for programming probably (2 sets of keys you'd get) and get Renault to fit them. (probably £200)
2) Just order 2 new keys using the present locks. Get Renault to order them and code them for £150 or so.
3) Contact j3ned and order a set of locks from a car he's breaking and get Renault to program the keys.
3) Same as above but get j3ned to send you all the new bits (ECU, UCH and the other bit which is needed) its not cheap but the only otpion Renault arn't needed for.
muz
cheers for the advice edde
after 2 days of searching still cant find them but I have a nice clean house now :)
Going to go down the renault route and just get 2 new keys and get them programmed. They won't be open till tomorrow though.
not happy but what can you do ?
muz
quick update
called Renault Assistance (In the manual it says it covers lost keys :) )
sending an engineer out, however I need to pay for parts but thats fine :)
so that could be ok
