little bit of help needed...
How the Fek do you remove the back of the rear seats ive undone everything that i can see that undo's and they are still stuck in, are they attached to the plastic bit that goes along the rear of boot? Hope that makes sense
the plastic that goes along the rear is just a cover for the 'iso fix' bar or whatever its called, they are bolted down near that aswell IIRC....take the bar out and you will see the other bolt
