inlet manifold chrome
  VRS
they polish and chrome you inlet manifold for around 80 quid
i was going to get this done but have been informed by numerous car and scooter (my dads currently restoring lambrettas) companies that chroming under the engine bay isnt recommended as the quality if the chrome is affected by the high temps as well as the chrome itself restricting breather pipes/spacings/bolts holes etc etc
i would highly recommend getting it polished tho :D
  laguna coupe
is yours polished
  VRS
is yours polished
thats a bit personal isnt it ;)
  VRS
polishing is around 50 quid for the mani, all they do is machine polish it!
you can always do it your self with some wet and dry and metal polish? thats what i did for most of my stuff
  laguna coupe
how what wet and dry grade did you use what metal polish did you use is there a guide to do it how long did it take you
  VRS
on my old mani it took about an hour per pipe on the four pipes!
you are looking at a lot of work doing it yourself but you can pick up around 5 grades of wet and dry (120-1500 grit) for about 15quid and some autosol metal polish for a fiver
just work through the grades till its smooth and shiney :)
  VRS
mine at the mo:
this is going on at the weekend:
  laguna coupe
where would you go if you wanted a proffesinal to do it have you do it all or just the bits you can eg under the pipes
  VRS
i take all the bits off and do them myself (doesnt take long to take it all off), if you look up a metal polisher in the yellow pages they will be able to gives you quotes! the only thing is you will have to take the bits off the car and leave them with the polishers for a few days whilst they do it
