engine fooked
aparently the sump on a clio rt (93) wont come off with the engine in place, the car was taken in for a new head gasket and the head needed skimming, but then there was no oil pressure when he assembled it back together so, a new oil pump was needed got one £23 took it down had it a day and the sump wont come off coz the chassis in places stops it from coming off. so he said he will have to take the engine out to do it, and also said that if the car has beebn driven around without good oil pressure for a while then the engine will be screwed anyway so i may as well get a new one. is this right or am i just getting f**ked up the arse!!!!!!!!!!!!!
  Not a Clio
similar problem with my Astra.
Had the head skimmed then 2 days later oil light came on... no oil pressure - oil not getting to the top pf the engine. Currently in the garage. From what the guy was telling me if its the oil pump then its cheap (few hundred), if theres a problem with the sump then its engine out and a 3 figure repair bill. Of course this is an Astra not a clio.....
  Not a Clio
id let you know what my situation is but Ive been unable to get hold of the mechanic.
dreading a huge bill.
all is good been told that i only owe him £180 at the mo for the head plus skimming, and he said hell take the engine out fit the pump and put it back in for bout £250, so nay to bad, so well pissed off, cars been trouble ever since i bought it but only the rear bumper to go on and the install then its finished.
  Volvo S60 T5
Drop the subframe down a bit, then with any luck you should be able to get the sump down, may need a bit of wiggling.
Ive done plenty of sumps on Renos never had to take the engine out
  172 cup,s2 rs turbo
yep bit tight but should come out. drop the subframe down a bit and lift up the engine slightly.
  172 cup,s2 rs turbo
do many k9k by any chance (bloody ots putting them bolts in the crank caps)
  Volvo S60 T5
Just a few mate, they seem to have tailed off a bit now.
Used to be a great bonus earner, sadly I get loads of leccy faults and running problems now, and the odd service, so bonus is out the window now:(
  172 cup,s2 rs turbo
same here mate your not the only one. i used to drop the subframe down for the k9k cos the electric steerings means its so easy to do.
ps-whats bonus?;)
