Cig lighter not working
  1.2 Clio Dynamique
Cig lighter is working but when i plug accessories in they dont work. I have looked at the fuse and that seems fine as the radio is also working so what is the problem? :(
  E46 320D Tourer!
there might be some crud in the bottom of the socket. had the same with mine, lighter worked but chargers etc didnt. gave it a clean out with a cotton bud and sorted. Dont use anything metal though, unless you drop the fuse out first.
just a thought, might be easier to do that first than checking voltages etc!!
G
Gregor11
Mine was the same mate, pulled it out, the little light bulb holder bit has moved, so when I turned it to the right place again it worked fine and has ever since!!
