Behind Hub Spacer fitting
I've recently received some hub spacers wih camber from M.A.D.
It's come with quite a few bolts, nuts etc. My dad & I plan to fit them. Has anybody got a step by step walk through?
Im sure we'll be fine, as my dad is less r****d than me when it comes to mechanics, but I wouldn't mind something to see,so that I'm 100% certain that each washer and everything is in the right place/order.
Probably a proper r****d Mongole post, but meh.
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Jack car
Remove wheel
Remove brake
Remove stub axle
Fit spacer (making sure it is in the correct orientation)
Refit in reverse
  182, SQ7, Trafic
Lol, you can't go wrong.
Jack car up and remove wheels.
Remove brake pad carrier and pads
Remove hub nut and rear brake disc
You'll then see four big torx bolts, undo these by holding the nuts on the back of the axle.
Then fit the spacer in between the hub and rear beam.
Then put your bolts through and put your washer and nut on the rear.
Put rear disc and brake pads and caliper back on then your wheel!
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
This is Harpham... he's a great guy even if he does wear childrens clothes but I can see this ending with one wheel toeing out and neg. camber on the other (and to clarify he doesn't wear actual clothes off kids, he's not on "the register").
Honestly, just help him lol
