anyone no how much it is roughly..
Free brake check somewhere? Just be aware somewhere like quick fit will always tell you that your brakes are f**ked.
  Audi A6 (S3 on order)
under seat should be linked to airbag light coming on I would have thought.... different issue.
I had a similar problem which was sorted by replacing the brake switch (by the pedal)
  MERCEDES CLS AMG
stupid question but the most common fault is your brake fluid level is low - just check it before you take it to Renault
under the sheet is normally your seat belt tensioner wire which is hooked up to the airbag sensor dont mess with it though cos the lil thing likes to explode :)
  2005 Impreza WRX STI
cheers for the advice lads! im going to have a look under seat ans look at sensors on brakes then if not obvious, try a free brake check see whats the damage!! lol
pm received mate cheers. got lots of ideas to be looking at, ive tried under the seat though n it seems fine so fluid and pads to do myself and look at sensors, after that its a garage!
