Accelarater & Clutch cables, feedback.
  Was a Clio 1.8 16v
My accelarator pedal has steps in it which spoils a smooth acclaration. Anyone know the likey cause and anyone had new cables or the same problem and has solved it please post me the soultion. Clutch grinds half the time when putting in reverse, is this simple a new cable due to the short performance clutch chatching when fully applied or is it new clutch time, anyone whos had the same prob please reply.
"all" clios crunch in reverse, it may help if you engage first gear then without taking your foot off the clutch put it in reverse. as for the accelerator, it is two stage. the throttle head has two holes. a little one for normal driving then a big motha f**ka one for balls out driving. around 2500rpm if you floor it your engine should produce a very deep induction noise
