removing alarm sensors
  Full Fat 182
Apologies if I'm being thick, but I'm unsure how to remove the alarm sensors from the A pillars inside my PH2 182.
Taking off the A pillars is fine, and unscrewing the sensors, but I need to get the sensors off the A pillars without damaging them or the A Pillar itself, as I need to fit them onto some new A pillars and if I damage the A pillars taking off the sensors, I'm only going to damage the new ones putting them back on!
Looks like it may be a soldering job?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
Normally the sensor clips on to a bracket which is screwed to the A-pillar.
To remove the sensor just insert a small flat blade screwdriver into the pivot point and lever it a bit to allow the pivot point to pop clear.
