Rear shocks gone...wet!
  Clio Cup
When I got home from work yesterday I noticed a rear shock on my phase 1 172 was 'wet'.
What is the consensus here?
Stay with standard or change to 'cup' shocks?
I believe I need to do both rears at the same time but are there any other parts I should be changing at the same time?
DrR
  VW Golf GTD
£90ish for two. Dead easy to replace. Just use standard ones.
Amos91
Honorary Member
Ok cool. With just new bolts top and bottom?
What is is process to replace?
Just use the existing bolts. Loosen off the top mount in the boot, jack the car up, remove the lower shock bolt and switch the dampers.
Reverse to fit. Torque bottom shock bolt to 105nm.
MRBILLYUK
  FF Jeden Osiem Dwa
I'm not sure if cup shocks will fit , I don't see why they wouldn't. Less than 66 quid here.
Or Phase 1 rear shocks , same price.
There are a couple of codes knocking about for free delivery .
Try RPD20 or cnet.free
  Clio Cup
Darren S
Yep - definitely had it that!
I think iirc, you need a 17mm socket for that bolt. Could be wrong be I recall it being a weird size when I did mine a good number of years back.
