query for megane 225 in to 182
  Astra VXR ex 172 owner
rite guys been offerd a turbo,manifold, and ecu are the engines the same and ecu is this possible if so wat else would i need do they fit a 182 arethe engines the same
cheers
1 more Meggy tryng to get into a Clio, I wonder why Meganes like to go into Clios so much...??
I think its not that easy...
cheers
Forget it
ECU isn't any use since stock megan 225 boost will casue trouble with the higer CR bottom end you have your better of remapping the stock ecu.
exhaust manifold need to be redrilled to suit
Turbos fine though just cannot use all the power it can make with stock cr unless you ue other tricks even then you'll kill it plus the clutch plus the box quikcly.
  Lionel Richie
exhaust manifold bolts straight on, edde "the master" is wrong, i'm the master of these here forums, and don't you forget it!!!! ;)
The intake ones doens't though from memory that the one I was on about im half asleep don't read or think staright. Its the bottom row of bolts which don't match up.
Are you over in Sweedon now?
