RichCup
EDIT: (AGAIN).. Noticed you got the Grp N mount from somewhere else, although I'm sure there both products of Vibratechnics?
Sorry I meant I bought it second hand, not from a different shop lol.
Love the progress you've made.
Did you just use a big drill piece for the the spot welds or a special spot weld drill bit?
Cheers I used a 10mm drill bit to free the bracket from the spot a little, then pulled the bracket off with some water pump pliers. Then just ground down the rest of the spot with the dremel. I'd recommend getting a decent quality drill bit, even some of the bosch ones I got were blunt after doing about 4 spots!
whos painting it for you?
Giving it a go myself mate
Cant wait to see the end result!
You taking her to FCS?
Cheers hew! Yeh should be at FCS hopefully!
