ktec uprated gearbox mount
  F4R'd ITB'd '92 cup racer
anyone else who has bought this, did it come with a main long bolt supplied?
if not what length/size does it need to be?
yeh the original will not come away from the rubber mount to be re-used, looks like it is manufactured that way
think its a bit of a poor do that k-tec didnt supply one
this is the thing, i'm not sure how long it has to be, too long and it will hit the gearbox, too short and i wont be able to get the nut on the end of it
i think its longer than 100mm, but not totally sure
K-Tec Racing
ClioSport Trader
  172LBT-172HBT-197-R2
The stud is in the gaer box mounting bracket and is not included in the mounts as it comes away from your standard mount, a firm clout with a soft blow on the top should shake it loose. We've never had a problem fitting them here and have never been asked to supply one before, hence it is not included.
Sean.
my bad then :eek:
i put it in the vice and gave it a good whack but not alot happened, i will have another go
you can get it out while still mounted on the engine...let the weight of the engine help you with it.
As a side note...Ktec you should include 12.9 bolts instead of 8.8 being a structural component and all it might be wise to err on the side of caution... just a thought
