It was how to activate the VVT, I was wondering what you might use on the ecu activate this.what problems are you up against with the wiring
If it's on a 730 then its just a simple make or break for VVT actuation so just drive it off a digital output. 830 requires PWM.
Emerald offers RPM switched digital outputs so should be a problem driving it and at least one of the outputs should be of a sufficent rating to drive the actuator directly.
M
Out of interest, would the VVT parts would be fairly simple to swap over to a 730 spec? They'd be fairly reasonable to buy new i'd imagine?
In "ECU configuration" tab on the top right of the software screen, 3rd up from the bottom is "output channels", set Vtec Switch to say Aux3.
This is a switched earth channel.
Then under "additional maps" got to Vtec switch and configure the switching points to suit.
Use the flywheel, its 60-2, reference angle=90*.
Are you sure you have to tap the inlet, I thought they were a straight swap? will check layter..
Why not fit a larger cable throttle body, whilst your at it?
renault sensor should be fine
there's no direct bolt on TB for the phs2, phs 1 plen and phs 1 TB if you want bolt on, or as you say, just turn the phs1 TB on a slight angle, drill and tap, job done
So that you can have infinite position cam timing over whatever angle the system allows.
I know on one of the newer Ford engines, a friend of mine is seeing 26bhp gain over the mid-range by accurately setting cam position for load/rpm.
