HTC Desire 626 wifi prob
  Clio200 EDC Lux
For some reason my HTC 626 desire can no longer see 5ghz wifi channels, I normally use my phone with my Bebop drone sky controller but couldn't see the wifi today. Had a check on my mrs phone and it can see the controller and 5ghz home wifi as well but my doesn't anymore.
Any suggestions? I can't see an obvious setting for it on the phone :(
Typhoon
Gangsta
Try going in to WiFi settings, click the 3 vertical dots to get into your menu, then select Advanced, then select WiFi Frequency Band, From there you have Auto, 5Ghz Only or 2.4Ghz only. If its set to Auto it should pick up 5, but since you're specifically trying to get 5 put it on 5 and see if it works.
