how do i fix this pipe? (with photos)
  182 cup
hi i have a power steering leak and ive worked out where it is leaking from
im going through bout a litre of fluid evry 100miles and even less if there is plenty of corners on the way
does lose any on straight roads though just obviously when the pump is turning and the pressure in the system increases eg.. 3 point turns
i have taken photos of the exact pipe and point where i believe the leak to be
i know the whole pipe is expensive to replace and fit so i wondered if there is any way to fix it as its not in a very awkward place.
its just at the the bottom under the car and is easy to access from beneath
anyone know or had a similar problem and how did they get it sorted
ive spent nearly £20 on power steering fluid in 2 weeks grrrr
thanks guys
the last photo shows where the pipe that leaking meet the pump... or what i think is the pump
and lastly which of these two pipes is it that i need if i do have to replace the whole pipe
any info very much appreciated
  titanium 182,
scrappy or buy a new one i would just buy a new one, by the time youve pratted around with it youd of spent the same money for a new 1
  BMW M135i
Not a cheap item unfortunately, thats the high pressure feed from the pump to the rack so needs to be right and hence expensive. Part number is 60 00 073 688 and £171 or thereabouts.
  1.4 N Reg Champs
scrappys it is then, if i got that from my local scrappy he wouldnt know it was worth 171
  BMW M135i
Finding one will be the problem unless your scrappys are far superior to mine, that and its not a 5 min job to get out and you need to get underneath the car to unbolt it from the rack iirc.
  Mk4 XR3i 90 - spec
duct tape ftw, or remove power steering. i recon scrappy would be better, or local hydraulics company, they're usually bang on and quite cheap.
  BMW M135i
The two realistic options i'd say are either bite the bullet and get one from renault or try a local power steering/hydraulics specialist they might be able to fabricate a replacement or repair that but I doubt that type of crimped end is saveable once it starts leaking.
  182 cup
its alot of money to spend on a car ive actually got up for asale at the minute for £4000 as ive lost my job
is there no way it could be welded?
i dont know if the leak is on the crimped part or on the metal pipe?
1
182kev
mine is corroded in the same place which renault uk said i'm the only one who has ever reported a corroded pipe on a cliosport,lol whatever
i've got one on route off a member on here who breaks them,it should be with me in the next coupe of days,if its the right one i'll pass his details onto you ;)
its £174 + vat for the pipe as its the main pipe from pump to rack,i went for a price last week and couldnt believe how much they were
  182 cup
kev is yours actually in the same place?
are you still driving yours round and just topping up fluid?
pm me how much you paid for the spare part cause i might still fix this if i can get it all done cheap enough
thanks
  Lionel Richie
try taking the pipe down to pirtek and see if they can sort it, we have loads of problems with the DB9's at work pirtek have fixed 4 of the pipes on our cars
  182 ff with cup pack's
thats the same pipe that went on mine and its the high pressure 1 witch is the 1 with the silver cover on a part of it and also the dear 1 lol goodluck
1
182kev
thanks
mines the same pipe and in the same place, hopefully the pipe will arrive today and can confirm price and member i received it off ;)
off on school run,reply shortly :)
  182 cup
cheers buddy look forward to hearing from you
i assume the pipe is the one on the left of the last picture??
thanks
This sounds like another common clio downfall ? :(
What material is the pipe made from ?
You'd think they'd make it out of a corrosion resistant material if it hangs that low to the round with all the s**t getting thrown at it
1
182kev
thanks
received today and its the right pipe mate ;)
pm joshydee hopefully he has more,depending on area the postage may differ but mine was £30 posted :D
thanks
£30 quid u little bas*~** i paid £180 for mine off renault
havin probs with a steering fluid leak too.
on the "2nd to last " photo .just above where he has drawn red. there is like a switch with a wire connector going into it..the switch screws into the fluid pipe
i cleaned all the pipe off and fluid is leaking from the switch itself.
is this a pressure sensor and how much? for the switch i mean. not the full pipework
it is the switch/sensor that is leaking that screws into the pipe. not the pipe itself.
i was wondering what this switch/sensor does
if it wasnt pressured then yeah some tape would be a quick fix,but if it is some sort of pressure sensor/switch then it must be under pressure?
and tape would last about 10 secs
  2002 Cup172
take the pipe to some1 who services and repairs JCB's or anythin hydraulic and et them to just make you a flexi hose to match thats all i did when mine went on an old car. cost about £40 or so
i did say it was the switch that is leaking NOT THE PIPE
i was hoping for someone to tell me what the switch actually is and how much
surely i can buy just the switch and not have to mess about with the pipe
it does screw out.
cheers anyway mr j cake..
if it ends up i need a pipe i might just do that idea of yours
  RenaultSport clio 182 cup
Driving along today then power steering failure , had a quick look looks like im leaking as well around this pipe!!!!!! Going to have a good look tomorrow in the day light. looks like another expence before xmas!
