Duragloss 901 is pretty good. Much preffered over Meg's Gold Class.
What difference does hard water make?
Buy some BTBM and you'll be fine.
If it helps, Meg's Gold Class didn't soap up too well for me, Duragloss 901 does.
Watermarks are a b**ch in this area.
I do struggle to get "good foam" from certain shampoos if but I get around that by using the hose set on its hardest/strongest setting (I got on of the ones that you keep twisting the nozzle and it goes from a liht mist to a "jet")
Fill it up in the kitchen a bit with hot water and top of with the "jet" setting..lots of foam.
Just using the kitchen tap doesn't get hardly any foam as it isn't strong enough. (pressure wise)
I don't know if I can be arsed! That £12 could go towards my £2500 repair bill for the evo!!!
what shampoo for hard water area? got megs gold class atm and dont like it, i know JD will sat BTBM but is there anything else thats good or should i go for Dodo BTBM?
All that fancy tech. Yaaaawnnnn control and then it costs a fortune. You need a 300% Fiesta that can be fixed with a hammer and duck tape.Ayc pump has gone. Well the solenoids have inside.
You can't buy the solenoids new, only second hand and they are 80 second hand.
Or you buy a new pump which is 2.5k
Sweeetttttttt
I use antifreeze
I use antifreeze
Funny you should say that... some say we are one in the same person.
Hard water = ice
Duhhh
ha ha ha very funny
