Complete 182 suspension refresh
Car  Full fat 182
I am looking to do a complete oem suspension refresh on my 182 with both cup packs. I've done some research and I'm struggling to find full list. I am looking at all bushes, dampers, springs and any other parts that are recommended to change, can anyone provide a list of what I will need to replace, but as mentioned want to only replace with standard parts. Thanks in advance Alex.
The Renault wish bones come with the bushes and ball joints mate.
So it will be.
1. Set of shocks
2. Set of springs, id fit the Cooksports if it was my car. Just gives a nice drop.
3. Pair of front wish bones.
4. Steering rack bushes.
5. Steering rack arms.
6. Track rod end's.
7. Front shock top mounts.
This is a list of what id replace if I was doing a full refresh. :)
So it will be.
1. Set of shocks
6. Track rod end's.
This is a list of what id replace if I was doing a full refresh. :smile:
How much would this set you back?
So it will be.
1. Set of shocks
6. Track rod end's.
+ front ARB bushes
Do the ball joints come with new bolts? Mines are and needing new ones.
I always refer to a post in the Renault Wolverampton Helen thinking of this job, it's a random request but has all the prices apart from shocks and springs, 172 prices
Wishbones £60 each
Steering rack bushes £24 each
Track rods £40.86 each
Track rod ends £37.94 each
ARB Bushes £7.80 each
Similar post also mentioned: inner tie rods
Mine needs new wishbone bushes, so getting oem wishbones fitted (believe these come with new ball joints attached?)
In a similar situation, thinking it's a good idea to do as much as possible whilst wishbones off. If I wanted to keep costs down, what do others suggest the priority list would be? I'm not sure how long each job takes (once wishbones removed) so this'll also impact!
Once you are at the point to remove the wishbones, you can easily swap suspension - the top mounts go with the strut.
The track rods are a bit fiddly but shouldn't add a great deal of time each side, I've no idea on the bushes. However, I'm just doing the track rod ends and they are seized so it may end up being the entire rod for me.
Okay, thanks masekwm, good luck with your tre's!
Money says I'm doing springs, dampers & top mounts another time, so deciding on the other bits. Reckon steering arms & track rods will be left out this time round, so prob tre's, arb & steering bushes if don't take too long.
Anyone had experience of how long it takes to do arb & steering bushes?
Thanks for all the replys exactly what I was after looked at both cooksports and ebachi springs but think oem but shall decide when buying. I want to get all bits first.
Some part numbers from a list I made before, when looking at refreshing my cup packed 182. You'd need to check your car has an SMI rack, but to the best of my knowledge most 182's do.
Chaski said:
ARB Bushes (Inner 23mm: 7700784170, Outer 25mm: 7700847383)
Steering Rack Bushes (SMI: 7701470760)
Dampers (Rear: 8200681125, Front: 8200681109)
Wishbones (N/S: 8200257956, O/S: 8200257957)
Inner Track Rod Kit x 2 (7701473656)
Track Rod Ends (NS: 7701474493, OS: 7701474492)
Top Mount Kit x 2 (543A09780R)
I also opted for these:
Chaski said:
Eichbach Pro Kit Springs (E10-75-001-02-22)
Eibach Camber Bolts (5.81260K)
And if you're itching to borderline waste £20... Powerflex Rear Shock Top Mounts (PFF60-311)! :P
That's gotta be £800 for just parts or there about ?
I have just had a phone call and been told just to get my front shocks sorted I'm looking at £845.
Sachs Refurbished @ BG
Lower ball joints
Track rods & Gaiters
Track rod ends
I already have Powerflex bottom arms & dog bone mounts along with AST solid top mounts.
Next on my list is to Powerflex the front Antiroll bar (Inner & Outer) as well as the steering rack and then also do the rear beam and rear shocks with power flex bushes.
That's sound marc, I guess with suspension its all down to how deep ya pockets are. I'm just about to refresh mine too but will only be looking at cup dampers, cooksports, top mounts, Arb and rack bushes. Thought about getting the power flex kit too.
From what I've read from other fellas, spacers work well and help fill the arches with a more OEM set up too.
