Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
chugging, flashing engine light n smell of petrol.
Discussion in 'Faults, Problems & Solutions' started by andyholden, Oct 19, 2012.
Tags:
  1. andyholden
    andyholden
    Oct 12, 2012
    5
    blackpool
    Car:
    1.6 clio dynamique
    as above i have just bought a 1.6 clio dynamique.
    there has been a slight knocking since i got the car (just exhaust i think) but it styarted to smell strongly of petrol when i got in car and then a couple days later after i had driven oin the motor when i stopped at lights i felt a chugging/shuddering through the car (felt like it was coming from engine) and then the engine light started to flash but the car would still drive. if i turned the engine of and on again the light would go for about 30-60 seconds then strat to flash again, but the car would only chug when stopped or setting of once i was moving and into second gear it wouldnt chug but light would stay flashing.
    i have searched the forum and seen alot of different things ir could be i was wondering if any one had any ideas and what order to check them in?
    thanks in andvance andy
  2. Mr bean
    Mr bean
    Feb 7, 2010
    309
    oxfordshire
    Car:
    Clio sport 182
    Sounds like a misfire but your best option is get the fault codes read first
  3. MicKPM
    MicKPM ClioSport Trader
    Oct 4, 2005
    7,959
    Nottingham
    Car:
    Clio16v/225 Trophy
    Most likely cause is a pencil coil pack fault.
  4. andyholden
    andyholden
    Oct 12, 2012
    5
    blackpool
    Car:
    1.6 clio dynamique
    will any garage have a fault code machine? :/
  5. benkay
    benkay
    Nov 1, 2010
    450
    Harrogate, N. Yorks.
    Car:
    V6 Ph2 + Audi S3(8V)
    Sounds very similar to when my lambda failed too. Decent fault code machine should tell you....
  6. Beef-Mc
    Beef-Mc
    Jul 20, 2006
    17,195
    East Neuk
    Very likely to be pencil coil, very common fault. Can check them by taking one out at a time, if engine sounds worse then its not that one, no change in engine noise then that be your culprit.
  7. andyholden
    andyholden
    Oct 12, 2012
    5
    blackpool
    Car:
    1.6 clio dynamique
    i have took the connectors of the pencil coils, the two outer ones when took of made the car engine worse but the two inner ones when i took them out made the car cut out i (took them out individually). what does this mean please?
  8. andyholden
    andyholden
    Oct 12, 2012
    5
    blackpool
    Car:
    1.6 clio dynamique
  9. andyholden
    andyholden
    Oct 12, 2012
    5
    blackpool
    Car:
    1.6 clio dynamique
    any one help?
  • Share This Page
