Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Battery Removal
Discussion in 'Faults, Problems & Solutions' started by vincent12345, Jan 29, 2012.
Tags:
  1. vincent12345
    vincent12345
    Jan 29, 2012
    1
    Car:
    Renault Clio 1.4 DCI
    What tools do i need to remove the battery on a 1.4 clio dci? and what is the removal process? Thanks in advance.
  2. wag1
    wag1
    Dec 30, 2011
    380
    Ongar
    Car:
    BMW 535d
    Hammer iirc
  3. edde
    edde
    Apr 22, 2003
    29,460
    There is no 1.4 engine its a 1.5dci (well a 1461 cc engine to be totaly correct)
    Anyway to remove the battery just need a spanner I forget the size maybe 10mm dead easy just remember to check you havee your radio code before doing it.
  4. Hamlet5
    Hamlet5
    Jan 4, 2012
    39
    Blackburn.
    Car:
    Clio 182
    8mm spanner for the two battery terminals, 13mm socket and long extension, for the battery clamp, if you keep the engine running while you change it, you wont lose the code!
  • Share This Page
