172 ph1 help please
  RenaultSport clio 172 mk1
Hi all.
picked up a X plate 2000 year Clio 172 ph1 last night and it has a few problems which i'm hoping someone here may have some ideas to try.
The radio won't power on, the display where the time, temperature etc should be is blank (in the centre of the dashboard), the electric door mirrors don't work (the electric windows do). the door open warning light stays on (have checked the bonnet pin). And the airbag light is on (checked connectors under drivers seat). Also the interior light in roof and map reading light don't work either.
I have also checked the fuses (well those in the panel on the passenger side that you can access after opening the door and removing the small panel) they are all ok.
Please any ideas or am i wasting my time?
  Megane dci 130
Check the front door connections are tight and have no water in them. And double check all the fuses.
  renault clio 1.4 si 2000
it may sound obvious, but have you checked behind the clock and radio to see if they're actually plugged in there? if all the connections are sound you may have to start removing panels and tracing wires :S
