will a phase 2 exhaust fit a phase 1???
  Mk5 golf gti
as title, just cat back
are they the same from the cat back, im under the impression that they are
i have the single lambda phase 1, will the phase 2 fit??
thanks
  Mk5 golf gti
:S Apologies i thought i posted in the exhaust section
could a mod move it please :)
Rob
Basically this all depends what length cat your ph1 has.
I believe I'm 100% correct in what I'm saying, but it's been a while since I've gone over it, so forgive me if I'm wrong....
The single lambda cat on the ph1 is a little shorter than the twin lambda version...
All ph2's had twin lambda..
So, any ph1 with twin lambda can take a ph2 exhaust, I believe.
  Mk5 golf gti
Yea this is what i thought too
damn ive got the shorter one so ill probs go custom
  2005 clio 182
I fitted an after Market exhaust from a phase 2 onto my phase1,as I had the twin lambda, but the bit that bolts onto the cat,had like an adjustable sleeve, so you could make it slightly longer or shorter, only problem is, where the phase 2 bumper is deeper than the phase 1 it looks like the backbox is hanging a bit low from the bumper
