There's loads of options for mixing and matching in the Renault range. You'd be suprised at what you can swap between F7Ps,F7Rs,F4Rs and F4RTs.
For example Scoff many moons ago dropped a 1.7 crank into an F4R engine to drop the CR. He then proceeded to blow stupid BHP through it using standard rods and pistons. Eventually he broke it but he was thinking outside the box.
You can put an f4rt head on an F4R the problem you have is the downpipe runs where the master cylinder is. Also you need to machine the head to fit an additional pulley as the F4RT Cambelt turns the water pump.
The other headache is VVT as mentioned the RS ones are too wild but the F4RT ones are too mild. There's not a lot of info about other cams in the lower models.
If I was in your position I would find the CR and power outputs from the Renault range that had an F4R fitted and work from there. As
@STEVE.M says something that is putting out 120 BHP is definitively going to have mild cams and a sensible CR.
One further note, all exhaust manifolds are the same but inlets vary loads. So meg 225 inlets are different to clio 172s, Clio 197 inlets are different again.
