Using oil
after driving to Southampton and back from Bristol on Friday (which is around 150 miles) the computer has told me the oil has gone down by 2 notches from being full. Is this something I should be worried about or is it normal?
  Renault Laguna Coupe
Perfectly normal while the engine is new. Mine used 2 litres in first 3k miles. Still uses a bit now, about 1 litre between services. 2 blobs on the computer = about half a litre by the way.
My Valver uses at least a litre per 1,000 miles - so count yourself lucky!
Sounds fairly normal. High consumption can be down to worn valve guides and so on, but is highly unlikely on a low mileage car. The high consumption on Valver/Willy engines is due to engine design.
