Change background image
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Torque wrenches and setting for hub nut?
Discussion in 'Engine, Gearbox, Exhausts & Running Gear' started by M@tt_182, Jan 11, 2012.
  1. M@tt_182
    M@tt_182
    Feb 2, 2011
    1,019
    Warwickshire
    Car:
    Impreza Wagon
    I'm going to attempt some DIY and replace a dead ball joint however it looks like I'll need a torque wrench for when I piece it all back together.
    Does anyone recommend any torque wrenches? Not looking to spend loads as it won't be used often.
    Also apart from the hub nut will I need to torque up any other bolts to a certain level when replacing the ball joint?
  2. LIL B
    LIL B
    Nov 27, 2007
    1,164
    Cuba.
    Car:
    CBR1K, F21 125D
    Halfords pro range are good for general un often use imo.
    Worth asking about for a local trade card (friend with one)
  3. M@tt_182
    M@tt_182
    Feb 2, 2011
    1,019
    Warwickshire
    Car:
    Impreza Wagon
    No one I know has one around here, I imagine it's a hell of a lot cheaper as well! The one I'm looking at is £80...
  4. welshname
    welshname ClioSport Club Member
    Aug 30, 2010
    8,349
    Unique Hair Club HQ
    Car:
    DSG Edition 30
    Torquing the hub nut to replace a Ball joint?!?!?!
    Only torque setting I use is QFT.
    If it's on the engine it's a different story though.
  5. montana
    montana
    Mar 11, 2003
    2,534
    North West, UK
    Car:
    Clio 197
    There is one for sale for £18 in the FS section, its 3/8 drive though.
  6. M@tt_182
    M@tt_182
    Feb 2, 2011
    1,019
    Warwickshire
    Car:
    Impreza Wagon
    I don't want to ruin the wheel bearing if it's too tight.
    That only goes to 80nm, I imagine hub nuts are 200nm+.
  7. mantis946
    mantis946 ClioSport Club Member
    Oct 16, 2009
    1,324
    Newcastle
    Car:
    Iceberg PH1
  8. M@tt_182
    M@tt_182
    Feb 2, 2011
    1,019
    Warwickshire
    Car:
    Impreza Wagon
    Second one is the one I need as it goes up to 300nm, typical it's the most expensive!
  9. Sam@NP
    Sam@NP
    Dec 6, 2009
    4,157
    Various
    Car:
    Lotus Elise
    275NM iirc
  10. Matt e
    Matt e ClioSport Club Member
    May 22, 2009
    1,940
    Herts
    Car:
    Megane R26
    ive got two halfords torque wrenchs, both seem really good used them a few times now, and they come with a lifetime warranty aswell
  11. Chapster5
    Chapster5
    Mar 22, 2011
    2,575
    Newton-Le-Willows
    Car:
    2009 1.4 Astra SXI
    Taken from Renault Diolagys...
    Tightening Torques (in daNm.m)
    Driveshaft Nut - 28
    Wheel Bolts - 9
    Shock absorber base nut- 18
    Brake Caliper mounting bolt - 10
    Track Rod end nut - 3.7
    Cotter Bolt nut on stub axle carrier - 5.5
    Probably no help
    Nick
  12. Blacky950
    Blacky950
    Aug 28, 2010
    461
    Penrith Cumbria
    Car:
    172 Cup
    Just done my hub nuts up and they were 280NM according to autodata.
  13. bmh.01
    bmh.01
    May 10, 2005
    11,941
    Nuneaton
    Car:
    BMW M135i
    Why do you feel them need to undo the hub nut to replace a ball joint????
  14. Fred@BTM
    Fred@BTM
    Jan 21, 2002
    50,042
    Birmingham
    Car:
    Lionel Richie
    as above, you don't touch the steering or the hub nut when doing a ball joint
  15. not normal dan
    not normal dan
    Apr 27, 2008
    3,032
    TMR HQ, deep depths of South Derbyshire
    Car:
    Megane r26
    Exactly what i thought, just the 2 nuts an bolts an the pinch bolt on the last one i did
  16. Fred@BTM
    Fred@BTM
    Jan 21, 2002
    50,042
    Birmingham
    Car:
    Lionel Richie
    and regarding the e-mail earlier, bal joints don't squeak, that'll be a lower arm
  17. M@tt_182
    M@tt_182
    Feb 2, 2011
    1,019
    Warwickshire
    Car:
    Impreza Wagon
    Oh ok, I think I read on another thread it needs to come off. At least that'll make the job a little easier, also a few people mentioned using a ball joint fork is it actually needed?
    EDIT: Just seen your post above :worried: I think I'll book it in for the work and save my poor hands the effort.
  18. .Stevo.C.
    .Stevo.C.
    Oct 9, 2008
    4,936
    Livingston,Scotland
    Car:
    225 Cup & Williams
    Ball joint removing fork is essential IMO takes them out the hub no problems.
  • Share This Page
