Taking hand brake cable out of calliper
haimsey
  ph2 172
Came to change a rear calliper today, all going fine until it came to separating the calliper and the hand brake cable.
Could not get it to shift from the guide hole in the calliper, surely it should come out?!
NorthloopCup
They can be a bit of a t**t if they're seized in. Usually a good thrashing and a bit of wd40 sorts them out.
haimsey
  ph2 172
No, not replacing the cables. If I use a punch/chisel to tap it out - not going to cause any damage?
haimsey
  ph2 172
Just for reference.
Got back under the car Sunday morning, looked at the metal sleeve on the handbrake cable/the hole in the calliper. Noticed that they weren't sitting quite parallel to each other. Tapped the metal sleeve at about 12 o'clock (used a flat ended punch and small lump hammer), and it came straight out. Tapping towards the lower half was just wedging it further in.
