Let the EGP cure for 12/24 hours then apply the wax.
No product is needed between these stages
Lols no but it should be that long between layers.Does it need to cure that long? Lol
You don't have to wait long on it curing mate you can buff off after a couple of minutes but you need to let it bond nicely to the paint surface.What if I heat the garage with the space heater? Can get quite hot with it! Lol! I don't have time to sit around waitin on it curing! Hahaha
NOOOOO
I mean after its been buffed off let it cure for 12/24 hours!
Also, you buff off after about 45mins to an hour
12/24 Hrs between coats? Balls to that! It'll get 2 coats in quick succession then I'll put the wax on the next morning! It couldn't possibly take 24 hours to bond!
Loves Rich's old 182.
Spotless and no miles!
I thought you bought it :S
Just skip the step if you don't want to use it properly.
As Russ said, SRP and onyx will leave a nice looking finish
No gap needed. Just fire it on. EGP dull's the paint tho. so. i'd wipe it off first.
de-grease - Swissvax cleaner fluid and then onxy.
Surely when you do a second coat it's just to top up and maybe get the bits you missed the 1st time? The EGP won't remove the layer below it as there is no solvent in it? So therefore if I do the EGP late at night then leave for 8 hrs overnight, I could wax in the morning? 24hrs seems excessive!
