Subs Subs Subs
  Clio Mk1
i would take the fli out becuase its just going to distort way before the black air and it will sound dodgey
ill be honest none of the subs distort at all now just the car shakes and sound s**t outside lol and i really need some new front speakers
  Chelsea tractor
Get / make some crossovers so that the smaller sub only emits sound within its capable range and ditto for the larger Vibe one. Hence it would be unlikely to distort as easily.
That it unless you just turn them up. Then they will distort ;)
  Polo + Micra
move the amp off the top of the other
you will cook them both
distorsion will only really occur if you play either sub past it's Xmax or you send the amp into clipping with too high/clipped input
  Clio Mk1
HOW DO I MAKE THESE ? and can i make crossovers for the front speakers? so they cant have bass through them becuase there good with no bass through them but even though on the headunit the bass is all the way off when its up loud you can hear bass through them but it sounds s**t!!
  Clio Mk1
whats clipping? clipped/input dont get it lol
  Clio 1.2
1000 Watt SHARK V9 High Power MOSFET Amp
1000 Watts music Mono- bridgable up to 400 W RMS
And Two 1250W Infinty Subs
  Clio 1.2
yeh i wont to it just will the battery be able to take it? and im not sure if me head unit and take two subs that why i needed to joing them together and by pass the headunit
