So many belts When to change them
Auxilliary belt, cambelt, timing belt? So many belts...
I am having a 172. It had run 25k.
When is the best time to renew the auxilliary belt? Haynes say 18k miles (for normal Clio MK2). Is that a bit too early?? Do I need to change the tensioner as well???
How about timing belt? Is that the same as cambelt? When should I change it in order to prevent serious problem? What else I need to change at the same time? Water Pump?
I want to keep my Clio 172 in good condition. oil change at 5k with throttle cleaning is what I do. What else? I had renewed my suspension with Eibach + Koni with Powerflex bumpstop. Is that necessary to change the suspension bushes too??? I hate to see my car got problem.
Well, please leave me some advice. (y)
I got my Cambelt changed at 42k because it needed doing. Dont wait until its "due" at 72k, its b****cks.... get it changed early to minimise the risk of damage.
I had my aux belt changed at the same time while the engine was out.
  Ph1
Got told by a guy at Reno that its not the cam belt thats a problem its the poly wheels which go brittle and crumble and then start to eat into the cambelt !!
A new cambelt kit should be fitted at 72 thou
Mine was changed only after 34,000 miles and about four years.
Luck of the draw im afraid.
Anything from £500-800 for parts & labour to sort.
Bit cheaper then £2k for a new engine as someone on here found out!
  172 cup'd extreme
timing belt at 36k? its the aux belt that needs to be changed at 36k or 3 yrs and the cambelt at 72k or 5 yrs
In an ideal world where everything is taken as gospel mate...
In reality however ;)
