Shock Absorber - tightening torques
  Clio 172 Cup
Can someone tell me the torque for the big bolt that holds the bottom of the shock to the subframe?
Also if there is a specified torque for the smaller 17mm nut at the top.
Done a search on here but cant seem to find anything.
Paul
  PH2 Flamer
Subframe? By Big 'bolt' I assume you mean the rear, as the front shocks have 2 bolts not one.
105nm for the lower bolt, top nut is 20nm iirc.
