Clio 200
Hi,
Is RS Tuning the only place that does mapping on a RR? Well only place with a consistently good reputation I should add
Looking to get a 200 mapped, but I want somewhere do a do a custom map on the rollers, ideally down south.
I've seen Mike mentioned a few times but it's not clear if he uses Surrey RR to just do a power run or to map on?
Also the OE ECU, am I right in thinking it is not mapped in the same way a standalone is, i.e the OE ECU is a series of power runs and adjusted reflashes vs a standalone where you properly live map and hold the engine at different load and rpm sites whilst adjusting live fuel and ignition values.
Not sure if I should find someone to make a p'n'p harness for a standalone or go with OE mapping really,
Cheers.
Cheers.
