Removing the fuel rail ?
Christopher.
South Central-South Coast
Chaps
What would happen if i just unbolted it and pulled it out the inlet?
Im removing the AC with the PMS kit and also wanting to fit my matched inlets. I can get to all the bolts on the inlet so that can come off. I just don't want to petrol p*****g out everywhere. Or am I being a tard and wont be a problem ?
Don't have a good record with flammable liquids :S
Chris
  172 Cup CC
If the rail is still plumbed in to the fuel line and you pull the whole lot out with injectors still attached then you will loose no fuel :) you will loose a bit if you disconnect the fuel line to the rail but it won't leak for long
  172 Cup CC
yeh, I always put a tiny bit of grease on the seals to help them slide in and make sure the seals don't pinch :)
